will Aero/Elite 125/150 wheels bolt to an Aero 50?
forrestking
Post by forrestking »
that's all ;)
I got my Aero 50 running, but the wheel is severely out of balance and may be bent pretty badly.
Re: will Aero/Elite 125/150 wheels bolt to an Aero 50?
Unknown on your question, but my guess is not.
However the Metropolitan rear wheel from any year is a bolt-on affair, wider for correctly-shaped 90/90 tire, and you can run it without a tube for a bit less unsprung weight. Brand-new from Honda for under $100, or try a WTB on TotalRuckus.com in the Met section. eBay has one pop up rarely.
Post by eliteguy50 »
Nope, will not work. You can interchange the wheels you mentioned between eachother but not with the 50. Look for any honda aero or elite 50 (not the elite E though) rear rim if you are looking to save some dough (buy a rim and tire shipped for what just a met rim would cost). If money is not a concern, buy a met rim and 90/90 as wheelman said. It will give you more speed and a better ride. I don't know about the unsprung weight part.
