Minibike vs. KX 250
vette66_00
Minibike vs. KX 250
I know we have talked about this before and alot of people dont believe a single speed, non-varated, clutch and chain minibike can be fast. So my question is do you believe a KX 250 dirt bike is fast, if so this minibike spanks it in the 1/8 mile at 71 mph (sorry didnt get the MPH gun in the video).
http://www.youtube.com/watch?v=Az4rMyIT ... r_embedded
89 Honda Elite E 48cc bbk and gears all broken in... I get to 35 mph (gps) full out and Im 240 lbs. Need more speed
My toy.. http://www.youtube.com/watch?v=LWgZXLUy25U
- Trafficjamz
Re: Minibike vs. KX 250
That is awsome.
But that did not look like 70 mph to me.
vette66_00
Here is a calculator for gear ratios
http://www.gokartracing.org/Calculate.htm
Front clutch 14 tooth
Rear Sprocket 55 tooth
Tire circumference is 35.3 inch
RPMS 8520 on a sendec tach
The calculator says 72.5 but you can have a bit of slippage but it should be compensated by the tire increasing in overall circumference.
So the GUN was not to far off.
yeah what size motor was in the minibike? if they are using a 15hp motor then yes it can be done. thats the same style motors they use in jr drags that go under 8sec. in the 1/8th
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- Trafficjamz
Yes, but all jr dragsters have a cvt setup to go that fast.
I don't know about the centrifical single speed setups getting to 70 mph in a 1/8th mile race.
- fastplastic
my go cart that was super light and use a john deer tractor tranny moved pretty quick with a centrial cultch and a 5 horse but d*** i dont know about 70 and i even had a tranny too so not tryin to be a * but one way to shut the na says up is get a pic of the gps on the bike
not all use cvt trans. with a 15hp motor modded and the right gears matched can go really fast.those motors can make about 40hp modded.Trafficjamz wrote:Yes, but all jr dragsters have a cvt setup to go that fast.bakaracer wrote:yeah what size motor was in the minibike? if they are using a 15hp motor then yes it can be done. thats the same style motors they use in jr drags that go under 8sec. in the 1/8th
91 yamaha tzr 250r
91 yamaha tzr 250r
- Trafficjamz
Well, all th Jr dragsters I have seen use a CVT.
I have a 13hp honda GX390 (389cc) Where can I find performance parts for it?
I would like to make one of these minibikes.
check the forums for those places. or kart sites.they use the 15hp 4 stroke motors on race carts for the 4 stroke class.
91 yamaha tzr 250r
91 yamaha tzr 250r
vette66_00
Trafficjamz wrote:Well, all th Jr dragsters I have seen use a CVT.
http://www.affordablegokarts.com/ is a good start they have all the stuff for your GX390.
Also these engines are putting out around 35-40 hp. Most are Honda GX200 blocks with about $1500 worth of parts and labor into them. The GX200 is a 6.5 hp stock engine. CVT's carry alot of drag as apposed to the clutch setup. Most of the clutches have a 3500-4000 rpm stall so the engine is producing around 30 hp on engagement. While I agree the CVT are great for low HP motors they are not so much on high HP motors.
If you check this video out on you tube http://www.youtube.com/watch?v=-oWS-mmAHaE you will see at 6:25 a pretty much stock gx390 (intake and exhaust) hit 47 by radar gun in the 1/8 mile. So he is make around 16hp at 47 in the 1/8 mile. More than double the HP and you will be hitting 70 in the 1/8 mile.
This is a pretty stock 6.5 Honda Clone engine (Harbor Freight $99.99). Upgraded parts to keep it safe at high RPM's. Stock carb upgraded jets, upgraded intake (adapter and filter) and exhaust, Gov removed, upgraded 18lbs springs form stock 11 lbs, running 92 pump gas, Advanced timing to 31 degs, and stock plug. About $250 extra into this engine but billet rod and flywheel are $170 of the cost to reduce failures and add no real power.
Most of you guys have been around Scooters to long and compare an Spree/sb50 to a dio motor and think the variator is what make's the difference and most of the Dio upgraded engines are maybe pulling 12hp?
- Trafficjamz
The CVT is what makes a elite S faster than a spree.vette66_00 wrote: Most of you guys have been around Scooters to long and compare an Spree/sb50 to a dio motor and think the variator is what make's the difference and most of the Dio upgraded engines are maybe pulling 12hp?
If these mini bikes had CVT's I think the times would be a lot faster.
I will build one this winter.....they look very fun.
Thanks for the link to the go fast parts
vette66_00
How about a Banshee Vs. Minibike Mind you this is a 6.5 200cc Honda Clone engine purchased at Harbor Freight, Although the only thing that remains stock is the block but its also been reinforced. From this weekends drags.
http://www.youtube.com/watch?v=DZieWVgw ... r_embedded
- Trafficjamz
freakin sweetvette66_00 wrote:How about a Banshee Vs. Minibike Mind you this is a 6.5 200cc Honda Clone engine purchased at Harbor Freight, Although the only thing that remains stock is the block but its also been reinforced. From this weekends drags.
how much does the mini bike driver weigh?
vette66_00
This guy "home alone" is about 160 lbs the mini weighs 110 lbs. Its another guys mini EvilEd but he is scared from the power it produces and is still getting use to it.
Here is a pic of the RPM's it turned in that race.
Here is Evil and his new engine before it went on his bike.
vette66_00
make sure to reinforce your block with high hp engines. lol
http://www.youtube.com/watch?v=NoTXFBts ... r_embedded
