carb intake size?
carb intake size?
hey guys, anyone know what the inlet size on the carb on a stock 2001 elite sr? i'm looking at ordering a cone filter and dont know what size inlet i need, need more air with my #85 jet!
stock 2001 Elite sr
Re: carb intake size?
It's 27mm. A UNI pod 1" angled filter will squeeze on. Remove all traces of fuel & oil using acetone-soaked Paper towel to be sure it stays on.
I thought that after cleaning, take some 220 grit sand paper and sand around the flange so the marks go around the flange would help retain a filter. Then there is always using some glue that is used to retain door molding on a car.
sweet, thanks guys.. do yo think you can maybe send me some links to find one?
stock 2001 Elite sr
- burnt_toast
both are nice ideas, coolBear45-70 wrote:I thought that after cleaning, take some 220 grit sand paper and sand around the flange so the marks go around the flange would help retain a filter. Then there is always using some glue that is used to retain door molding on a car.
have had times where i could've saved a road flying filter if put these ideas to use..
projects galore
If your going to run a uni filter with that 85 jet is going to run lean and seize. just punch out the second tab on the outer lid of the airbox and get the 88 jet from a 88-93 elite 50 lx/srsgray913 wrote:hey guys, anyone know what the inlet size on the carb on a stock 2001 elite sr? i'm looking at ordering a cone filter and dont know what size inlet i need, need more air with my #85 jet!
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
d*** really? i already ordered the uni pod filter and it came in the mail already, but still waitin on the #85 jet..
stock 2001 Elite sr
