Chinging sound at full throttle
Re: Chinging sound at full throttle
you have to use a new plug when doing plug chops.if not your going to get a false reading.that plug is to hot for a bbk. run a cooler 8 plug.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
How long do you run the new plug in the engine before doing the chop? I've noticed that a mile run (down and back) isn't good enough to get good coloration on the plug. Perhaps that's because I am using a 6 plug?bakaracer wrote:you have to use a new plug when doing plug chops.if not your going to get a false reading.that plug is to hot for a bbk. run a cooler 8 plug.
On a side note I saw 56mph today with the new belt 8g rollers and the 140 main.
1988 LX50 Elite DIO
use a old plug to warm the engine up and then put a new plug in. a 4-5 second wot is good enough for a plug read. yeah if the plug is to hot the porcelain will clean itself off to quick. so a plug chop is warm the bike up with a old plug.put a new plug in. get up to speed and hold wot for 4-5 seconds.use the kill switch to shut the engine off while holding it wot and come to a stop as quick as you can so you don't get to much extra air and fuel to screw your plug read up. use a number 8 plug. that should be just right for your setup.zajaco wrote:How long do you run the new plug in the engine before doing the chop? I've noticed that a mile run (down and back) isn't good enough to get good coloration on the plug. Perhaps that's because I am using a 6 plug?bakaracer wrote:you have to use a new plug when doing plug chops.if not your going to get a false reading.that plug is to hot for a bbk. run a cooler 8 plug.
91 yamaha tzr 250r
91 yamaha tzr 250r
Here is the most recent attempt with a BR8HSA plug and a 140 main. Im not sure if I am not stopping fast enough or what but im not getting much coloration out of these either.
1988 LX50 Elite DIO
bump that pilot to a 58 and run the 142.try that and see if that ground strap gets darker.it looks gray.look for a smoke ring at the base of the porcelain also.
91 yamaha tzr 250r
91 yamaha tzr 250r
I defiantly got better coloration with the 142 main and 58 idle. I didn't have to adjust the a/f screw with the new idle size... The motor reved up and down smoothly with the A/F about 1.75 turns out.
The grounding strap has good color but the porcelain is still white. According to my chop chart here that still puts me a bit lean. I think I need to go up one more jet. What do you guys think?
1988 LX50 Elite DIO
OK those plug charts you see are for 4 stroke plug reads. the 2 stroke plug chop reads are the base of the porcelain and the ground strap. the mid to top of the porcelain will still be white with a new plug. your looking for a smoke ring at the base of the porcelain and the coloration at the ground strap. your ground strap looks good. what is your compression at right now? do a cold and warm engine compression test.whats your oil to gas mixture?
91 yamaha tzr 250r
91 yamaha tzr 250r
Ah, thanks for the heads up. Yes, there is a smoke ring near the base of the porcelain.
Cold compression: 135
Warm compression: 131-132
Fuel to oil: 32:1
Fuel to oil: 32:1
1988 LX50 Elite DIO
