Common symptoms of a bad bystarter?
skelter79
Post by skelter79 »
I have an 87 Spree that takes like 30 kicks to start when cold. When warm it starts with 1 maybe 2 kicks. Otherwise the thing runs great. Does this sound like a bystarter problem? Just wanted to get some input before I bought a new bystarter! Thanks!
Re: Common symptoms of a bad bystarter?
If after it starts it runs crappy and you have to keep it reved up with the throttle, then yeah, it sure sounds like it.
Clivester
Post by Clivester »
Depends on what form of "bad". There are usually 2 situations.
Stuck in extended position - bike will be hard to start until warm as described above.
Unable to extend - (the wax has leaked, the element shorted/discontinuous, or wiring issue) the bike starts easily but runs like crap when warm due to too rich condition.
Check the bystarter off the carb, measure the needle tip distance from the plastic case, apply 12V (polarity not too important), after 5 minutes re-measure. It should extend several mm. Can also check resistance across the wire and compare with spec in service manual.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
grm
Post by grm »
I am having a similar problem, do they make a manual choke that fits or a different carb that will work?
Yes.
https://www.1977mopeds.com/product/1535 ... Choke-Kit/
The problem is you have to run without plastics, cut a hole in them or rig up some sort of linkage.
Fishman43
Post by Fishman43 »
Good link Bear, I would run one of those if I hadn't spent so much time getting a functional bystarter.
tazland001
Post by tazland001 »
d*** bear that manual choke looked kewl. You guys always find the coolest little gadgets.
Taz
tazland001 wrote:d*** bear that manual choke looked kewl. You guys always find the coolest little gadgets.
Taz
I actually didn't find it, I just saved it when some one else originally posted it on here. I figured if my bystarter ever when crapo, I'd just do the manual thing like I did on my F250 with it's 460.
