1996 SA50p slowing down
funbelly
Post by funbelly »
ok well i have a 1996 elite that has around 9800 miles on it. as of right now its only running about 25mph but it use to go around 35mph i was wondering if there is any tuning tips to make it go faster again.
also does anyone know where i can get a cone filter for the carb on this model some kids ripped my airbox off last night and stripped the bolts so i need to replace it with a cone filter...
i just want to get my baby running again its to nice out for it to be sitting on the side of my house
thanks
funbelly
martynkim
Re: 1996 SA50p slowing down
Post by martynkim »
First of all Welcome! and stop storing it outside! If you have read around you have seen clean the carb and then clean it again!
bakaracer
Post by bakaracer »
funbelly wrote:ok well i have a 1996 elite that has around 9800 miles on it. as of right now its only running about 25mph but it use to go around 35mph i was wondering if there is any tuning tips to make it go faster again.
thanks
funbelly
Welcome! the big reason right now your going slow is because your missing the airbox so the engine is running lean.by just putting a aftermarket air cleaner is not going to solve your problem. if you do get the aftermarket air cleaner ,you will also need to get bigger jets to compensate for more air thats going into the motor now or you could just find another airbox.if you keep riding the bike in the lean condition ,you risk seizing the engine. then you will have a bigger problem.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
funbelly
Post by funbelly »
well i just cleaned out the carb yesterday bc since the airbox was ripped off i felt like it was needed... what size of jet would i need to use if i go with an after market air filter. and does anyone know a reputable site to buy both of these items?
thanks
funbelly
Gungatim
Post by Gungatim »
My SA50p only ran around 20mph as it was missing the airbox cover when I got it. I made a plate out of sheet metal to cover it for looks but it is basically just sucking air wide open through the filter. I had to drill the main jet to .81mm and now it runs 37mph after I removed the ramp plate and drilled the exhaust washer. Hope that helps point you in the right direction.
Current lineup:
'66 Honda CT-90
'70 Solex
'74 Solex Horse
'77 Hobbit
'78 PA50II
'78 Express
'81 Express II
'79 Puch Maxi-Luxe
'87 Razz
'95 Elite
'51 PM putt-putt
'64 Daimler-Puch
Happy Time 80cc motorbikes (2)
Man, I really need a Spree!!
funbelly
Post by funbelly »
ya that does give me some ideas i have already removed the exhaust washer a while ago but i guess i could just grass roots fabricate a filter system
